PowerTool
After spending most of my spare time in the last four months involved in a house refurb,have finally got back to having at least some free time I get to choose how I spend it
Started off with something easy to get back "in the swing of things" :wink:
Couple of mushrooms in yew,both about 50mm diameter,80 + 110 mm high,finished with friction polish.
Recently bought some plastic bud vase inserts,so thought I'd better make a couple :-
Sycamore,60mm max. diameter,100 mm high,waxed..
..then made another,and had a play with some Chestnut spirit stains.
Had an idea of what to do with a smallish slab of burr elm (320mm x 230mm x 60mm) - turned a small bowl recess,then added some small feet made from some wenge offcuts I had :-
And then made an ornamental egg and eggcup :-
The egg is made from spalted hornbeam,60mm diameter,90mm height ; eggcup is pau amarello,60mm diameter,85mm high - both finished with acrylic lacquer.
Did consider going to Harrogate today - but think this was much more enjoyable 8)
Andrew
Andrew
