TS blades again
Tusses
21 May 2008
coventry
I asked for recommended brands last time.
This time I am after a combination blade, with a bias to cross cutting.
I need to get a decent blade . When I rip, I usually finish with a jointer/plane
If I can get a clean cross cut and sand to an acceptable finish that would be fine.
so - I need a 10" blade. What should I buy ???
I will buy a seperate rip and crosscut later if needed - but I am getting the opinion that a combo blade will be satisfactory to start with.
my current 'screwfix' blade from my old cheap contracter saw is dished ! I want one that will stay flat.
so .... come on .... recommend away !
Rich
Almost anything other than Screwfix! Axminster sell some pretty decent ones or go for Freud.
Roy.
I get good results from a freud blade.
Must be about 30 teeth and im afraid I'm too lazy to swap it between ripping and cross cutting, real wood or ply/mdf or chip board.
I've got to go down to the workshop soon so i'll edit this with the blade type later.
HTH
Bob
Another vote for the Freud, although I have found the triton 40 teeth blade supplied with the saw also very good.
Harry
yep - as for brand I will try Freud / CMT or maybe perform as a cheapy
I was imagining around 40 teeth.
I was after specific blade recommendations - i.e. a part/model number of the one you use !
thanks again -
Rich
You don't mention what you want to cut nor the arbour size Rich.
Roy.
arbor size is 5/8 or 16mm but I have reducer rings for 30mm - so not much of an issue.
as for wood - just about everything.
Hard Wood / Soft wood and Ply (yeah - I know ! :D)
but still - a good blade should cut better than a bad(cheap) one ?
probably looking for a better finish on the hardwood side.
If you're prepared to pay the price I'd go for Freud's ultra fine cross cuts, they do a pretty good job on ply as well.
BUT you might well need a new riving knife as they are thin kerf blades.
Roy.
how thin ?
my riving knife is quite thin too. I have a 2.8mm blade on now that is thicker than the one's I got with the TS.
ok - while we are on that - I had a stack of blades with the saw - but they are the old type - not carbide tipped. so havent even considered they might be good blades !
I have the full range (maybe 8 or 9 types) of cross / rip / ply / fine ...
would these be usable (i guess they are, because they were sill being used ! )
but - they would need sharpening regularly . how much would it cost to get blades sharpened ? and how often do they need doing in comparison to TCT blades ?
Can't remember the thickness now. You could Google Freud and see what you get.
Carbon steel saw blades tend to take a better edge than Carbide and thus produce a cleaner cut.
But of course they don't hold that edge as well, they also tend to be thinner so your riving knife might well be a thin one.
Roy.
Ta !
Ive seen that one ot rutlands ... but why does it saw it's only good for portable saws ?
is it ok for Table saws ?
also - thats a 7" or there abouts
I'm after a 10" to keep the speed correct. ??
Tusses":xlw5grpx said:
Ta !
Hmm! so it does? but if you look here
http://www.powertoolspares.com/blades2. ... LP30M+025P
the same blade is listed for stationary and portable saws.
The cut depth limiter design is certainly a good idea for portable saws but I don't see why Rutlands exclude its use for table saws.
I use it in my TS and it has done a lot of good work both ripping and cross cutting.
Maybe someone else knows the answer?
Bob
Nope! But for fine finishes on cross cutting I would like to see more than 40 teeth on a 10 in blade.
Roy.
HAHAHa ! LOL
I was looking at the picture of the blade !
it's got 184 printed on it !
Rich
ps - have you got 9 fingers ? or is that just your user name ?
if its 9 - then where is the other ! if you dont mind me asking ?
I don't disagree Roy but the results with my 34 tooth/235mm blade (even less than 40/250) has been giving good results dross cutting oak, beech and iroko recently and tonight I've pushed through some 1/2" resin coated birch ply with no chipping of the resin.
Bob
is it easy enough to sharpen the old blades yourself ? I guess like sharpening a hand saw ?
Tusses":1zik5kd9 said:
HAHAHa ! LOL
Rich
There is a story behind the 9fingers.
Nearly 3 years ago I joined this forum when off work due to an accident with my P/T. I had planed the upper surface of my middle right finger from nail to second joint. I cut though the tendon and a few mm of flesh.
The surgeon joined my damaged finger to the next door one with a flap of flesh being donated to the damaged finger from the good one complete with a blood supply from the good finger. In this way the graft is more likely to take. So for several weeks I had 8 standard fingers and one double one hence choosing my username.
Now thanks to a tendon transplant from my leg, flesh from the adjacent finger and skin grafts from my arm, I have 10 working fingers and a debt I can never repay to a surgeon called Caroline McGuiness from Salisbury Hospital. She was prepared to attempt reconstruction to full movement when the standard repair would have been to fuse the joint rigid.
Sorry i don't have any gore pictures to Wizer standards but as I am right handed, taking photos would have been difficult but I did drive my self to hospital as at the time my wife had just had a new wrist joint fitted and was in plaster herself.
Bob
