Not even a Makita?Not that anything's perfect, though ...
Yeah that's exactly what would happen, and I'd just not settle with it.If your not happy now after fiddling with it send it back as you will always be hesitant,
anyone else have a recommendation for new at the Triton sort of price area?
You're absolutely right, and I backed right off when doing some additional tests, even doing quarter- and then half-turns which, if I remember rightly, equated to a max of ~.8mm or so.Only time I have experienced any "thud" or bang on my TPT125 was when I set the thicknesser too low (using the side tape/depth measure on the side) and ended up taking too much off in the first pass. This also ended up with snipe at infeed and outfield. I now slowly reduce the height of the blades initially allowing the rollers to feed the wood and then continue to lower the blades until they start to remove wood. Found that this also reduces the snipe or gets rid of it all together.
I'm not saying the OP is setting the blades too low and this is a (possible) cause of what he has experienced... just you can't trust the set of the measure on the side for depth/height of blades setting.
Sounds very much like you ended up with a "Friday" job... one being finished on a production run on Friday... ☹ Incomplete assembly and *testing* before packing for dispatch.You're absolutely right, and I backed right off when doing some additional tests, even doing quarter- and then half-turns which, if I remember rightly, equated to a max of ~.8mm or so.
The thud was accompanied by the wood making a quick upward rock prior to then being engaged by the cutter. So, workpiece is fed through the infeed, roller engages and the tail of the wood visibly (and of a significant amount) rocks up and then back down before being held firmly through. I now assume this is due to the play in the bed allowing the workpiece to not be resisted by the bed but instead push it down until it meets the frame the bed should be fully resting on.
I mentioned above that I removed the bed plate last night; one thing I didn't state is when I held it up, it's quite well warped, too.
That is very handy to know, thank you. I shall be doing that on tonight's tests!I did find that I had to hold the wood flat on the infeed table, pressing down slightly, to not allow the weight of the roller just before finding the blades to lift the first part of the wood off the infeed table and it then dropping back down.
