i do exactly that too on my axminster. Drop it by 1/2 to 2/3rds of a turn each pass, which takes about a mm off. it will do more, but like you it probably adds a couple of minutes to the task and leaves a better finish.
marcros":18wqx0ws said:i do exactly that too on my axminster. Drop it by 1/2 to 2/3rds of a turn each pass, which takes about a mm off. it will do more, but like you it probably adds a couple of minutes to the task and leaves a better finish.
John15":18wqx0ws said:One of Peter Parfitt's New Brit Workshop U Tube videos shows him fitting an Axi thickness gauge on an Axi P/T. So I bought one to fit on mine but months later it's still sitting on the shelf - I don't really need it - another impulse buy which seemed a good idea at the time!
I don't know that particular model, though I've always been impressed with Axminster customer service for parts.Alf Beharie":245pzihk said:I have just bought a used Axminster MB1933 planer/thicknesser on ebay. It's got an 1800 Watt motor, same as the Dewalt DW733 which I used to have, but it can cut a bit wider 330mm vs 315mm. I haven't had a chance to use it yet but hopefully it will be as good as the Dewalt. I need to get a dust extractor shroud for it as that was missing when I bought it...I have contacted Axminster about it and I am awaiting their reply. If they cannot supply one then I will have to make one.
One bonus from having the MB1933 is it has a choice of two feed rates...Both of them being slower than the Dewalts single feed rate, so its planning quality, in theory at least, should be better.
It's a tad naughty not to mention that in the sale (I assume he didn't)?Alf Beharie":2rb2vxpr said:The motor was running fine but the cutting roller and the feed rollers were not moving!...Took it apart to discover the drive belt had snapped!!...Not only that but the previous owner had tried to glue the broken belt together again...with epoxy!!!
sploo":18fnfavl said:It's a tad naughty not to mention that in the sale (I assume he didn't)?Alf Beharie":18fnfavl said:The motor was running fine but the cutting roller and the feed rollers were not moving!...Took it apart to discover the drive belt had snapped!!...Not only that but the previous owner had tried to glue the broken belt together again...with epoxy!!!
Still, if the price was good then you've still probably got a good deal, allowing for the cost of the consumables.
Ouch.Alf Beharie":zn4c4vpo said:I paid £220 for it!
sploo":24zl022o said:Ouch.Alf Beharie":24zl022o said:I paid £220 for it!
