Picalilli
Hi all - looking for some advice on the triton mof001 or other triton routers and the options to fit bushings or template guides? I'm mainly wanting something that will allow me to use templates and set up guide fences when routing freehand. I considered just getting flush trim bits with top bearings but I thought maybe having the bushings would be more versatile in the long run.
The full bushing kit from triton seems to be around £90 and the sizes are imperial (I'm not sure whether it matters if they are imperial/metric - is this just a preference thing?)
http://www.axistools.co.uk/125249
Trend also do a base that says it fits the mof001 and will then accept any trend bushings, but I'm wondering if it would also take the brass, backing ring type that you can get quite cheaply online?
https://trenddirectuk.com/trend-gb-...cwSN4ophikGkV8cf3UyT7oEm57G-FHxIaAtl0EALw_wcB
https://www.amazon.co.uk/KATSU-Rout...la-819821598615&ref=&adgrpid=79390523034&th=1
My third option is to try to make my own, but not sure if this is trickier than it seems as the cut-out for the bushings has to be bang on to ensure they fit perfectly centred...?
be great to get a steer from someone who owns one of these routers and has either the triton kit or went down the trend or make your own route.
