CYC
Well done Neil, outstanding table. Outstanding work. I would have defintely messed up cutting the insert, by half a millimeter :roll:
Neil Wrote..
So did you melt a router, then? What do you think of the door/no door decision?
waterhead37":vzpblvjg said:I reckon a modification of the Incra design could put all its best bits into a much less space hungry package
waterhead37":399t2z4j said:Like a hinged surface, .........from the back of the router table.
So if I am right, it begs the question of why routers are burning out. I really am not convinced it's lack of air flow.
Wulf, I finally remembered to check this last night - with 6kg of router hung off the insert, it isn't crowned at all - in fact, if anything it is a tiny, tiny smidge the other way. Maybe it is optimised for 5kg routers :wink:wulfric":1e2lxbcn said:Everything I have read about router tables always stresses the importance of flatness of the top. But the Rousseau insert that I have is slightly crowned, deliberately I believe, which sort of defeats the flatness argument doesn't it?
