I would use my Trend guide clamp much more if it was easier to set square to an edge. I can never set it accurately! To overcome this, I’ve made a simple T square guide to help set the guide clamp accurately.
It started off as two pieces of 12 mm plywood with two square edges. One was then set on top of the other at 90º to make a simple T square. I then screwed them together.
A couple of notches had to be cut in both the upper and lower rail of the T square to allow the end of the clamp to fit. I laid the clamp in position, marked its position against the plywood, then removed the screws and cut out the notches. Then I screwed the T square back together.
It’s a very simple jig which I’m hoping will serve me well for years to come.
Edit: On re-reading, this seemed even less clear than it is now, so I've changed some phrases .
