Richard T":1h421pxk said:
Thanks for the encouragement John, truth is I haven't tried it yet. I've got as far as unearthing an old (English) dovetail saw and overhauling it.
I've sharpened it to full rip angles. I've had it appart, cleaned it, oiled it and put it back together. ...
I've done the same recently - and I've also discovered how to re-tension the blade resulting in instant improvement in blade straightness on an old Tyzack 12" tenon and an old S&J 8" DT, as follows:
The blade in a trad backsaw is a dry fit in the folded brass back. To tighten it you hold the end 2" of the blade in a wood faced vice and give the back immediately above, a sharp tap or two with a hammer. Don't over do it. You can do it at both ends.
You are effectively tucking the blade further into the back, at the ends, so pulling it tighter along the edge. A bit like pulling a sheet straight on a bed.
Only takes a few seconds for a dramatic improvement in a wavy blade.
