Crazy thought, would a felt tip do it?memzey":6vp6ep7w said:I just wondered if there was something akin to a pencil that could be used to colour in PU as a bit of a cheat.
memzey":ze84nb1n said:- I just wondered if there was something akin to a pencil that could be used to colour in PU as a bit of a cheat.
memzey":3rtcqqc3 said:Cheers MCB I might just do that. Did you pick them up in Hemel? In which case it was Aldi. Our nearest lidl is in Borehamwood.
BTW I took your advice and picked up some Shield technologies rust remover. Only had a little play last night but looks promising.
memzey":95ism932 said:Interesting. I bought the gel rather than the dilute stuff. It seemed to work well during the little time I played with it.
If that kind of timeframe doesn't bother you you should try molasses in water, you'll be just as impressed and it'll no doubt save you a bundle.MCB":21csgmjw said:I use the diluted RESTORE in an ultrasonic bath and leave it for a few days before stiff brushing under running water. That's freed up items that were rusted solid. I was very impressed.
memzey":1vli9pa5 said:Oh and I had another pop at sharpening the iron again tonight and succeeded this time. Not sure what I was playing at the other night but this big old plane is now taking beautiful shavings. With all my other vintage tools right about here is where the restoration would stop but I feel like I'm going to go a bit further with this one. I'd like to see if I can "sympathetically" restore it to a condition that's like my No. 7.
The treated item would need to be kept warm, just an initially higher temp probably won't do enough to see any difference because it's a relatively slow reaction.memzey":24vhbt2o said:That's also interesting. I tried it in a freezing cold shed on a freezing cold bit of cast iron. I wonder if it would work any better if I were to warm up the item or the gel beforehand? I'll give that a go too at some point.
ED65":15d8uex4 said:If that kind of timeframe doesn't bother you you should try molasses in water, you'll be just as impressed and it'll no doubt save you a bundle.MCB":15d8uex4 said:I use the diluted RESTORE in an ultrasonic bath and leave it for a few days before stiff brushing under running water. That's freed up items that were rusted solid. I was very impressed.
ED65":2j3au8l5 said::| I meant in the long term, once the (no doubt pricey) Restore is gone.
So don't eat it! Not difficult to treat it like it was household bleach or something else you wouldn't take internally.MCB":359hc1cf said:My experience with Restore is that it's good value for money and the firm that make it has very helpful courteous people who respond quickly to After sales queries.
Since I'm diabetic, I would NOT want to have Molasses in my home!
