Toggle latch
HOJ
21 Oct 2014
South Norfolk
Anyone know where I could look to get some catches like this one, the toggle latch part isn't really a problem its the hook plate design I cant find.
Most of the latches I can find work in the same plane, this one is at 90 degrees.
Thank you @Inspector & @ChaiLatte , out of interest what did you use as search terms, nothing came up for me, having said that I didn't use 90 degree as a description, there are more than enough options in your findings.
Really appreciate your help.
...what did you use as search terms...
I have known of Protex for ages. I suggested them as a likely source rather than a positive lead. It was purely luck that a catch of the same shape as in your picture is in one of their pictures. I hope they are not misleading us both by photographing something they do not sell.
Silly cheap at screwfix where I got my last bag of them..
...got them from screwfix, I just searched toggle latch
Silly cheap at screwfix...
Please see highlighted in bold some important information from the original post:
"the toggle latch part isn't really a problem it's the hook plate design I can't find"
Please could you provide the Screwfix code for a product that meets this requirement. Thanks.
As I already said, silly cheap at £6.00 for a complete pack of 10 latches and hooks..of course if things are that tight you could go online and find these at £0.81 + vat for a single hook part although p&p will probably
still make it more expensive..
I appreciate your input @Terrytpot but the ones you suggest will not work for my purposes, I need one that works at 90 degrees as outlined in my OP:
Tbh, it would probably be easier just to buy a length of flat bar and just make one..bend the end around a small screw, mark out and drill the mounting holes and then a final bend before cutting to length and de-burring.
