There is nothing special about the shelves. The spacing is governed by flats on the leg castings.Robbo
Could you put a photo up showing the shelving under your 1628 lathe. I’ve often thought it would be a good idea.
D
Good advice..... i found a second hand hairdryer that i keep attached to my lathe, not only is it good for fast clear up but the warm setting is good for 1: warming hands in winter and 2: warming my 5 minute epoxy in winter so it comes out of the bottles better.An easy to make holder to stop your tools rolling off the lathe. Drill a line of holes in a batten then cut down the length. A batten underneath is used as a stop - or a pair to straddle the bed.
The tool handle was made from beech taken from a kneeling stool, hence the dowel tenons. I'll bet there's not another one like it.![]()
Bandsaw light.
Even though it's fairly light in my workshop I always seem to be in my own light when using my little bandsaw. By chance I came across a 30 LED lamp on Ebay for £6, sold as a sewing machine aid.
Conveniently it has a magnetic base & it's own power switch but the lead is a little too short so I cut off the 2 pin plug (it comes with a 3 pin adaptor), drilled a 5mm hole in the top of the column & wired it directly to the bandsaw switch. Now the light goes on & off with the machine.
I was so impressed that I bought a second one as a movable temporary light for where ever it's needed.
Nice! Yes, it seems we have had some good ideas!An easy to make holder to stop your tools rolling off the lathe. Drill a line of holes in a batten then cut down the length. A batten underneath is used as a stop - or a pair to straddle the bed.
