Does a plastic table saw handwheel repair count?
BentonTool
UK Tool Junkie...
UKW Supporter
15 Mar 2024
Benton, Pennsylvania, USA
My friend Stuart recently purchased an older Craftsman table saw with a broken handwheel.
The handwheel mates with a hexagonal nut to activate the tilt mechanism.
The plastic was split and did not grip the nut with enough force to work properly.
I dismantled it and mounted it on my lathe for the repair job.
Epoxy and hose clamps (along with duct tape) will fix just about anything!
Loving the jubilee clip 👍👍
Bigger the better generally. As the saying goes you can do little stuff on a big lathe, but you can't do big stuff on a little one.
What is it out of interest?
"you can do little stuff on a big lathe, but you can't do big stuff on a little one."
My friend Mike says that all the time... :)
It is a SHELDON 13 x 36 INCH M-SERIES LATHE Catalog # TE 1236 P, Circa 1951, similar to this one, but with a chip tray:
Very nice, I thought I had seen the headstock before in the dim and distant past an old guy I knew had one here in the UK and he loved it I always wondered what happened to it when he past.
I have a Holbrook CB 8 with the electronic speed control.
