Robbo3
Spanners for the lathe.
Lathes tend to use fairly large hardware. Even if you have the right size spanner getting the room to use it can often be a problem. Luckily, you only need to make adjustments on the odd occasion & unless you posess a socket set then a cheaper option is a box spanner.
With the variation in sizes, especially at the larger end, spanners tend to be somewhat expensive. Those made of pressed steel, or home made, won't take a much abuse. At long last there are some cheap (£6) adjustable spanners available from China. They look to be cast aluminium which should be stronger than the pressed steel, home made polycarbonite or wooden ones. Their shortcomings should be outweighed by their short length & massive adjustability.
