Dr Al
Were they stainless steel screws? They're notorious for that, as are brass.
No, they were these: WoodSpur Torx Head Premium Self Countersinking Wood Screws
("gold-zinc" plated steel).
next time round try to pre drill the hole ........
I suspect the pilot holes may have been too small. So, for example, if you were using no 8 screws, which are equivalent to 4 mm diameter shank screws, the norm is 4.5 mm diameter for the clearance hole and 3 mm diameter for the pilot hole (plus countersinking if using a countersunk screw), which works well for softer woods, e.g., walnut, cherry, pine, etc: but with oak, and some of the other harder woods, a 3.5 mm pilot hole is generally required. It's also a useful trick to smear a bit of candle wax or similar on to the screw thread prior to inserting the screw. Slainte.... two of the screw heads snapped off while I was tightening them.
