RogerS
Does anyone know how this stacks up against softwood?
Or even better, know what the figure is?
Many thanks
Many thanks
So oak is a better insulator than softwood and so I should be able to reason with my BCO and say 'therefore I can get away with (probably not the optimum words to use ) a thinner insulation layer in my plasterboard.
jasonB":2dvouoxg said:NO roger, oak has a lower R value (thermal resistance) so will transmit more heat, not helped by the fact yours are 80mm rather than the usuall 47mm.
Jason
CHJ":1sil0qww said:(R-value )
1.4 per inch for most softwoods
0.7 per inch for most hardwoods.
A 3-1/2" insulated stud wall has a value of about 14
EDIT: I knew I had a reference somewhere
