clogs
just can't decide
Doug....it takes real skill to make em like that....lol.....
think of the complex joint angles.........
You're not implying that I said timber will retain moisture indefinitely, are you? I didn't, but I have experience of large beams of timber (oak) that have been air drying outside sometimes for a few years where the shell is quite dry but the core is very wet.Air dried to 18% is easily achieved outside in the UK and that will also occur in a roof space in Paris. Just because a timber has a large section, it doesn't mean that it will retain moisture indefinitely in a dry space.
I'm not implying anything Richard, it's what you said upthread.You're not implying that I said timber will retain moisture indefinitely, are you? I didn't, but I have experience of large beams of timber (oak) that have been air drying outside sometimes for a few years where the shell is quite dry but the core is very wet.
You may well be right about air dried timber in the UK achieving 18% MC. In my case it's been rare to come across air dried stuff that's dried outside as low as that. More commonly, my experience is that air dried stuff that is at 16% - 18% MC has either been shifted from drying outside into a dry building with some airflow, or was dried from the start inside such a building. Slainte.
just to add......
I built an extension to my old house in France...I wanted exposed timbers to match the rest of the house......the main beams were cut fresh and supported for 3 years....
after that the pit props were removed, they dropped about an inch....
sorry the photos are poor....but u'll get the idea......
having done quite a bit o work for our french friends I can assure u cutting a 200 year old oak beam 30x30cm is like cutting concrete....
a nightmare up a ladder one handed.....man it eats chains.....hahaha.....
front and back
As for the FRench, we had many french locals that I would call friends......and were still in touch....
our particular area was run by an obnoxious mayor and his cronies....they cut my fences and tried to steal my sheep and I cought em red handed cutting down some oaks in my PRIVATE wood.....plus many more acts of nastyness.....
ps... we did loads of charity work as well.....
We lasted 17 years but we'd have gone in10 if the original sale hadn't fall thru.....diff to find somebody who want 8 hectares....hahaha...
the average Brit lasted on average 5 years and many didn't go that long.....
As we were leaving this mayor was being arrested for corruption and theft....I rest my case......
You're correct Adam. I misspoke in error and you spotted it Thanks. I'll make a correction here and leave the original as it is on the basis that anyone that's read this far will see the correction.I'm not implying anything Richard, it's what you said upthread.
"All the same, any oak larger than about 100 mm square in section is going to take years to air dry to something like, at best, 20% MC here in the UK: lower moisture content may be achievable in drier parts of Europe. In reality, a large piece of oak, 150mm+ in section is most unlikely to ever air dry through to the centre to 20 - 25% MC."
