Adam W.
A Major Clanger
Maybe it's you and not a nation of 67.5 million French people that's the problem ?If u had lived with them for 17 years u'd understand.......
Surely you mean they had to live with you for those 17 years.If u had lived with them for 17 years u'd understand.......
Wow thats inspiring where s me cassocknot really interested in anything the French do....
if u want a spire with a twist...pun intended..u only have to go to Chesterfield, Derbyshire.....hahaha......
Here we go againMaybe it's you and not a nation of 67.5 million French people that's the problem ?
It's a perpetual merry-go-round of jolly japes.Here we go again![]()
Well building the original spanned 200 years- so I'm sure it will be perfectly re-created by 2024......Macron has declared the complete, whole restoration of the Cathedral must be finished before the Paris Olympic Games in 2024
Ding Ding......round 1Here we go again![]()
You're right. Kiln drying is a relatively modern innovation so anything made out of wood before about the late nineteenth century would have been either air dried or green. Big lumps of oak used for the construction of barns, cathedrals, churches, large houses, etc would have, at best, had some time to dry a bit stickered up in a draughty shed. All the same, any oak larger than about 100 mm square in section is going to take years to air dry to something like, at best, 20% MC here in the UK: lower moisture content may be achievable in drier parts of Europe. In reality, a large piece of oak, 150mm+ in section is most unlikely to ever air dry through to the centre to 20 - 25% MC.Side stepping the French issue..... & Brexit implications....
It is the green oak bit that interests me. I have crawled arond the interiors of a couple of cathedral roof spaces looking at the construction & joints. I would assume that during the lenthy build time the spire & roof were open to the elements, so from that guess the timber was not dry when it was pegged & jointed.
Agreed. Wood in roof spaces tends to settle out at somewhere between 16% and 18% MC. That applies primarily to occupied buildings, e.g., houses and commercial buildings. At what MC the wood in the roof space of Notre Dame cathedral will be dependent upon how the building is used and what climate control measures are in place in the used space, but my guess is that the wood in the roof structure will eventually reach numbers reasonably close to the ones I mentioned above. Slainte.It will most likely end up being much drier than 20% under a roof.
Let's also not forget that the carpenters working on this roof are Compagnons du Devoir or their apprentices and will certainly know what they are doing.
It will be a deliberate choice. The practicalities, time required and cost of kiln drying large baulks of oak for this type of job would be enormous, and a very large failure rate is highly likely, e.g., case-hardening, core collapse, honeycombing, shakes/checking, etc. Oak is a particularly refractory wood to dry, and kilning big lumps of the stuff is virtually unheard of. In reality, air drying a, say, 250 X 250 mm section beam of oak to an MC of 20% or below just isn't going to occur over even a number of years, certainly not in the climate prevailing here in the UK, and I'd guess throughout most of, if not all of France.I do wonder whether use of green timber was a deliberate choice, or whether it was driven by logistics - no kiln drying, time taken to air dry, storage capacity, investment required to cut and transport oak before use etc.
Air dried to 18% is easily achieved outside in the UK and that will also occur in a roof space in Paris. Just because a timber has a large section, it doesn't mean that it will retain moisture indefinitely in a dry space.Agreed. Wood in roof spaces tends to settle out at somewhere between 16% and 18% MC. That applies primarily to occupied buildings, e.g., houses and commercial buildings. At what MC the wood in the roof space of Notre Dame cathedral will be dependent upon how the building is used and what climate control measures are in place in the used space, but my guess is that the wood in the roof structure will eventually reach numbers reasonably close to the ones I mentioned above. Slainte.
Lots of spires like this through France.not really interested in anything the French do....
I wonder if the guy who worked on that went on to do cls production for B&Q![]()
