Inspector
Nyuck, Nyuck, Nyuck!
- Joined
- 18 Jun 2006
- Messages
- 4,642
- Reaction score
- 2,787
- Location
- Saskatoon, SK., Canada. Elbows Up!!!
uziwood786 it is a good thing you didn't ask how to do it with a dinosaur bone or there would be the added aspect of creationism verses evolutionism to the mix and would the dinosaurs have used math, geometry or rule of claw to figure it out.
I being a new world barbarian would have used the table saw by attaching a sacrificial wood fence to the existing fence, tilted the blade to 35º from vertical, and brought the spinning blade up into the sacrificial fence until the tips were buried. Pass some scrap along the fence to cut the bevel. The eventual top will be down on the table surface. THERE WILL BE TRIANGULAR SLIVER/OFFCUT THAT WILL PROBABLY SHOOT OUT TOWARDS YOU. MAKE SURE YOU STAND ASIDE. Put a sheet of plywood or OSB behind you to stop the offcuts from poking holes into stuff you don't want holes in. You can refine the bevel by dropping the blade and repositioning the fence and then bring the blade back up until buried again. Once happy you take your stock, pre-cut to length and width and bevel both long sides, then without touching the fence use the mitre gauge to hold the piece against the fence to cut the ends. All the bevels will be the same. Set up fingerboards for narrow stock and feed with push sticks. Now if you really wanted to raise an eyebrow or three you would use a dado stack
rather than a single blade. The wider cut would eat up the wood that would have become offcuts and removed the waste kickback hazard.
