I hadn't delved too deeply into the OP's question as I thought that it had been adquately answered but now I look back I see that is far from the case. It seems that no one has answered the subsequent question about how
@johna.clements got the angle from the 1.52 calculation.
This is simply 'Maths' - 1.52 is the tangent of the angle and the actual value (in degrees) has to be 'looked up' from a table of Trig values - or today - keyed into a calculator/phone app.
Now the real question is what does the OP really want? - He has specified 2 criteria : the 'platform' should be 30mm wide and the 'skirt' should be 6mm.
@Jacob's suggestion to set the saw at 45° would not achieve this without reducing the total height of the plinth.
Here is a drawing showing three posibilities :
[ A ] shows exactly what the OP has specified and to achieve this the angle Alpha needs to be 34.778° - which makes Beta 55.222° - both of which are cumbersome to set up on any type of saw. If the 6mm is not sacrosanct (and I cannot see any reason for it to be so) then making Alpha 35° would force the skirt to be 6.148mm.
To maintain the 30mm table width and use a 45° angle, the skirt would be 11.5mm as shown in Fig. [ B ] The alternative of maintaining the 6mm skirt would make the table width 19mm as Fig [ C ]
Given that the OP knows that the total height is 24mm and that he wants a 6mm skirt the he must use arithmetic to determine the 18mm dimension. Similarly knowing the width is 55mm and he wants 30mm left, only use of arithmetic can determine the 12.5mm dimension. Simply guessing a setting on any sort of marking stick and scribing that same value on each face (to get a 45° chamfer) will never achieve any of the criteria specified.
Personally I would settle for a 35°/55° setting - though as far as suggesting a location for a fence is concerned, we simply don't have sufficient information to give an unqualified opinion, but assuming the 35°/55° option is taken and that the job will be done on a table saw, then here is a drawing showing the figures :
This (hopefully) shows the two posible methods and I'm sure there will be equal support/opposition for each
Naturally, the precise width (nominally 55mm) height ( 24mm) and length (290mm) of the initial blank will have a bearing upon the final outcome.
[EDIT] - apologies to
@johna.clements - I missed your responce detailing the Tan-1 explanation (though I doubt that the OP would have really understood the true implications!)
