johnnyb
I do feel the angle at the cutting edge is getting steep(zoom in and check the reflections) probably not an issue now but only after a few visits to the buffer.
Interesting, I am finding the angle I need to apply the gouge to the wood to cut is very high. I know it’s ground at exactly 25 deg. Perhaps I am holding it at too high an angle when sharpening and taking off the edge. I will try again tomorrow.I do feel the angle at the cutting edge is getting steep(zoom in and check the reflections) probably not an issue now but only after a few visits to the buffer.
If you look long and hard enough there is some more advanced help too. It just takes a while to find it.As far as I can tell in-cannel are for paring, and if you want to gouge out a hollow of any sort with them they won’t work for that.
I had another go with mine today and it’s way better than it was. Not quite professional perfection yet, but maybe 70% of the way there.
It’s great to have the resource of this forum for advice, YouTube has lots of beginner stuff, lots of what to buy videos, but little serious detail. I guess in the past people would have apprenticeships to learn the ropes.
This YouTube video might help with sharpening.Ok, thanks Johnny.
The reason I asked is that I read somewhere (on a carving website) that they should be sharpened at 10 deg so a 25 deg scoop is easy.
Hi Adam,First off, you need a gouge of a suitable size for the cut required.
So get a larger gouge.
HiEvening
These planes I’m making are starting to work really well, but I’m still not there with recreating some of the finer details. I realised my gouges (which I have very little experience with) may be sharpened incorrectly. Or at least I want to eliminate that as a reason for messing it up all the time.
So, to create a gouge cut like the one in the picture below, I presume I need an out cannel gouge? What angle should I grind the primary bevel?
Hi Steve. I'm not sure about bevel angles, but I will say that all my gouge cuts on the planes I make are done with the same chisel which is an in cannel scribing gouge .Its probably about 1/2" wide. This is very easy to control, and works very quickly and efficiently with no additional clean up requiredEvening
Steve
Steve
A small selection of gouges would cover it. I doubt that you would need a separate gouge for each size of plane.Hi Adam,
So are you saying that the cut should be approached from the “long side” of the cut then? Would the gouge need to exactly match the width and sweep of the cut? I need to work out which gouge(s) to get.
If so, for a set of planes, there’s a lot of gouges to get….
Steve that’s some very impressive work, the kind of level I hope I can get to one day
But basically we are talking about a gouge as long or longer than the length of the cut I suppose.A small selection of gouges would cover it. I doubt that you would need a separate gouge for each size of plane.
And cut downhill, so yes approach from the heel along the length and not from the toe of the plane.
Not really as you can lengthen the sweep by rotating the gouge whilst progressing diagonally through the cut.
With practice a 10mm gouge will easily produce a finished 40mm curve, but the gouge needs to be quite shallow and very sharp.
Another way is just to match the sweep and size of the gouge to the cut you want to produce and just knock it off with a mallet, but that requires numerous gouges all sized to the cut you want to make.
