OK, we all do. But for this particular task of making square sapele blocks to insane accuracy, my "manual edge fettler" works better for me. It's way more efficient and much more accurate! I struggled with the sheer hardness of this wood and the masses of grain reversals when trying to shoot it on all four edges. So I fell back to the fettler - a general purpose thingy - which worked great! Sometimes, the simplest and crudest solutions are best...
The fettler is just 150 grit sandpaper stuck to glass with a metal "fence" that is free-standing and can be moved anywhere on the sandpaper. Everything is straight and square on this fence, but a chunk of squared wood works too. Note: the "fence" is a component from an optical bench in this case - covered in masking tape so it can resume its original function, one day, maybe.
To square and dimension the edges of the sawn blocks, I simply press the reference face against the fence, an edge against the sandpaper and slide the block back and forth along the fence, applying "rotational pressure" with the right hand to tilt an edge one way or the other if needed. The edges stay flat on the sandpaper though - there's no actual or visible rotation. Generally the edges are square already and just need knocking down level. Note: the left hand usually holds the fence steady but mine was busy holding the camera here.
Checking progress (size) on the dial gauge is super quick, just seconds, and it's easy to see if edge has tilted out of square as one corner will be higher than the other. If that happens, I use the little square to verify which edge is at fault (top edge or bottom one), rub the edge while "rotating" to apply more pressure on the higher end, then check again. And so on...
I've just completed 64 squares, each 63.00 x 63.00 x 26.00 mm. I used two decimal places as I managed a tolerance of +/- 0.03 mm for the lot! Yep, that's +/- 30 microns!
Hope it's not too humid tomorrow or I might have to sand more off to get it back in tolerance...
