Alf
Better and better - done dealBenchwayze":17g9oi9q said:That's true, except my Gents saws do have brass backs.
As it happens... :wink: After a lot of experimenting with the cheap methods I finally gave in and use a cobalt bit. They're not too outrageously expensive these days and get the job done in a brace of shakes. Recommended. Alternatives are to heat the area you want to drill very locally by application of friction with the aid of a power drill and suitable blunt instrument to the spot - or punch, grind off the dimple and adjust the hole to fit with needle file. Both these take time but they do work.Benchwayze":17g9oi9q said:I could fit 'pistol-grip' handles. I have actually considered this, but how would I drill through the saw blade (tool-steel) to accommodate the fixing nuts/bolts, without softening the metal? Surely I would have to do this, which would ruin the saw? Unless things have developed so much that I can now obtain drill bits to do this without softening the metal. In which case I plead my failure to keep up to date.
Only problem is once you've done it on one it can get to be a bit addictive...
Cheers, Alf
