bridger":bhh3mntu said:
That suggests to me that stropping is more a burnishing process (plastic deformation - moving metal around) rather than an abrasive process (removing metal). Putting it another way, the main effect seems to be slightly reshaping an edge by deforming metal to where it's wanted to make a better cutting edge, rather than by abrading it to form a new edge in new metal.
From a purely personal observational point of view, that rather confirms what I find when using a slate polishing stone. There seems to be only slight metal removal, but when I treat tool edges by only trailing them on the stone (rather than the usual honing practice of back-and-forth), I end up with edges that seem sharper than almost any other way I've tried. I've noted the same effect on an ultra-fine ceramic stone too. That practice seems to both remove the wire edge from the main honing stone (fine India in my case, or medium ceramic in the past), and burnish the honed edge to a better 'finish' than the honing stone leaves.
That effect does not happen if I use the same back-and-forth technique on the slate as I use on the India, or at least, not as quickly.
I've no proof of this whatever, but my suspicion is that leather, palm of hand, piece of hardwood dressed with compound or undressed, or polishing stones, all do the same thing - burnish rather than abrade.
