Derek Cohen (Perth Oz)
bugbear":3une21de said:OK; we now have a definition of what stropping does; it removes the last traces of the burr, but (again defining what stropping isn't) not by abrasion.CStanford":3une21de said:In a woodworking context, and in my view, all it does is remove rag -- the last shards of the burr -- and that's it. It if smooths or contours the edge in any way that's not stropping, that's back to honing.
So what is the mechanism of stropping, and (for bonus points) why is this action different in linen versus leather?
I'm aware that I am (in effect) asking "what is stropping" again and again, but since I keep failing to get a concrete answer, I'll just keep asking.
BugBear
Hi BB
I thought this was obvious? Or perhaps this is just my understanding ...
Stropping involves the bending of the wire, which occurs from one side of the bevel to the other, until it snaps and falls off.
I imagine that, as a blade dulls, the edge is not just worn away, but also bent back, especially in softer steels (overly hard steels are more likely to fracture). Stropping a used blade either straightens the "wire" created from use, or it straightens the edge (moving the steel). I have microscopic photos of the bending from use, but not seen photos taken after stropping. This is all just my supposition. Someone should taken some photos of the process. Or do you know of any?
The point that I was making in my previous post - which are so important that the forum software duplicated it!
Regards from Perth
Derek
