Thank you for getting in early - I'm just back from the workshop and I concur. Without taking it all apart I couldn't say whether the table has to come off to get access, or if you could sneak a spanner in, or if the front (red) panel comes off a frame.Emstuv":3j59idu6 said:On the front of the table there are 2 bolts, one in each corner. I'd say they are set in about 15mm from the table front edge. A third screw is placed in the extension table for support.
Yosarian":yc5oopew said:What are people using for a dust extractor for this?
I have extremely limited space, but my NVD750 only pulls about 300m3/hour, which is well below the required 850m3/hour. I just about have space for a 1HP chip extractor (https://www.axminster.co.uk/axminster-c ... tor-105111 for example) with the collection bag mounted in some sort of external cupboard, which would just meet the minimum 850m3/hour on paper. However, I'm also aware of other sources like Bill Pentz (http://billpentz.com/woodworking/cyclon ... corner.cfm) who recommend at least 1000CFM (~1700m3/hour) for adequate fine dust extraction. I just don't have the space for something this powerful.
Whatever extractor would be used in conjunction with my Airshield Pro, as well as an extractor fan and Record air filter. I suppose my question is: am I wasting my money on a LPHV 1HP chip extractor? Or will it significantly improve dust collection over my HPLV NVD750?
Thanks.
Sent from my SM-N950F using Tapatalk
Does it mean that using this saw with an industrial vacuum that has a flow of about 220 m³/hr (that´s what I currently have) is absolutely pointless?bp122":dfwwwk0g said:Hi there
I use Axminster Craft AC82E 1.5HP Dust Extractor with the AC216, with a filter upgrade to the cylindrical type (not HEPA)
The extraction is rather good, but not so great without the suction from the blade guard as I use my TS without this (modified riving knife to cut partial sections on the workpiece)
kstano83":ewr9bzqi said:Does it mean that using this saw with an industrial vacuum that has a flow of about 220 m³/hr (that´s what I currently have) is absolutely pointless?bp122":ewr9bzqi said:Hi there
kstano83":3caucdeh said:Does it mean that using this saw with an industrial vacuum that has a flow of about 220 m³/hr (that´s what I currently have) is absolutely pointless?bp122":3caucdeh said:Hi there
My question is - what's wrong the existing fence?kstano83":q9w0fgpy said:I´m getting keen on this saw and wondering if it is technically possible to put a "John Heisz´s fence" on this without too much hassle.
https://www.youtube.com/watch?v=FIhMBYwm9E8
https://ibuildit.ca/plans/wooden-table-saw-fence/
Once the rails of the fence are removed, are there any holes where it can be attached?
kstano83":1xo9ipnj said:Several reasons. My plan is to make extension wings or build it into a workbench for bigger capacity so the original fence would be too short and basically useless. I also would like to make it incremental with incra racks or a threaded rod.
Is it any good?Trainee neophyte":11irjyel said:kstano83":11irjyel said:Several reasons. My plan is to make extension wings or build it into a workbench for bigger capacity so the original fence would be too short and basically useless. I also would like to make it incremental with incra racks or a threaded rod.
Have you thought of the sliding table upgrade? It's a bit more expensive than a good mitre gauge, but does all you list above, and it does a lot more, too.
Trainee neophyte":7sg95foj said:kstano83":7sg95foj said:Several reasons. My plan is to make extension wings or build it into a workbench for bigger capacity so the original fence would be too short and basically useless. I also would like to make it incremental with incra racks or a threaded rod.
Apparently it is significantly better than the one that came with the TS200. It isn't going to be Felder standard, no doubt.Yosarian":2fu69ar8 said:Is it any good?Trainee neophyte":2fu69ar8 said:kstano83":2fu69ar8 said:Several reasons. My plan is to make extension wings or build it into a workbench for bigger capacity so the original fence would be too short and basically useless. I also would like to make it incremental with incra racks or a threaded rod.
Sent from my SM-G977B using Tapatalk
Bodgers":2amxgjjj said:[Apparently it is significantly better than the one that came with the TS200. It isn't going to be Felder standard, no doubt.
I think there are few peeps on here that have it...
It's a good machine, and for this price you can't go wrong.kstano83":106lq54p said:The AC216TS as currently on sale for £477/580€. I couldn't resist and placed an order.
kstano83":2r2pvlpt said:I made a croosscut sled for my AC216TS with plywood runners and they are harder to slide on the front and the back of the miter slots as if they were different width. Has anyone experienced this?
I have two runners and it drags even if I place the sled the other way around. It slides perfectly in the middle but it´s tight on the edges. Right after I cut the runners I tested the width by sliding both ends into slots to see if they are loose or tight. They were perfect in the middle but too tight towards slot ends. I might get incra miter sliders to see if it´s the same with them.Trainee neophyte":pirpgct0 said:Because I know me, if I had this issue, I would assume it was the sled, not the saw. Do you get the same effect if you turn the sled the other way around? Do you have one runner or two? If there are two, then if they are not 100% parallel they will tighten up unevenly. Wax will always help a bit.
