Hello gentlemen,
I am now making a saw bench with hand tools only. I have found an issue with my tenon saw. It is not sawing coplanarly. I have started to saw big dovetails for the bench. The top cut is square to the face and the front cut follows the line. The angle is the same on both front and back tape. The back cut wanders off to the side.
I had the same issue when cutting these boards to length. The top and front edges were square and the back and bottom edges wandered off. The board is 120x40 mm. Is it possible to get such big cross section right out of the proper tenon saw or the shooting board is always necessary? I just cannot get it coplanar, so I always err to the waste side and then finish off with the shooting board for square cuts. For dovetails, I would need to pare off the back side and it would save me a lot of time, if I could get it right from the saw.
Interestingly, when cutting square small cross sections, like 20x50mm, I can get it right off the saw without the shooting board.
Thank you for any advice.
Front view
Top View (does not look square, but it is - growth rings and distortion make it look out of square)
Back view
Tenon saw is straight
Front view
Back view
