GazPal
bugbear":204juqyr said:GazPal":204juqyr said:ali27":204juqyr said:Guys I need a workbench, but I am not willing to pay 200-300 for
such a thing. So either I need to buy second hand or make on myself.
Now when I think of building a workbench, I think of a flat wood/mdf top and four
legs and that's it. Seeing pictures of workbenches I noticed that there were many
extra pieces of woods, between the legs and in other parts. I am guessing that
just four legs is not enough stability. I have very little tools so I need to make a bench
that is super easy to make. Help is appreciated.
Thanks.
Your options are endless, but you could start by making a pair of trestles and use a sheet of 8'x4'x1" ply (Split down it's length) doubled in thickness, or a few lengths of 6"x2" (Glued edge to edge with bread boarded ends) faced with 0.5" ply for your worktop. Simple and inexpensive, but not as simple as providing 4 legs with stretchers linked via mortise and tenon joints or dowel bolts. A saw, hammer, jack plane, pencil, tape measure, square and couple of chisels are all you need if tooling is a limitation.
I'll point out that a bench for stock preparation using hand planes needs to be very stable, since the forces are high. Hand power-tools work doesn't need much more than a sturdy table (work can be held for routing by mere friction, hence the "router mat")
BugBear
Suitable bracing tends to negate problems and the some of the best examples can be found on site where bench construction tends to be limited to what i'd described, yet capable of supporting most handwork activities.
