Tannin marks after Oak glue up
JoeS
27 Jan 2020
London
Never had this problem before, but working in some American oak this week on a small table and after wiping away the glue with a damp brush like I usually do I've ended up with what I think are tannin stains. Drat and double drat!!!
For now that means lots of fiddling sanding to do...I'm assume the marks will come off with a sand? But how to avoid this? Just be more careful with glue? I've always wiped my joints with a damp cloth/tooth brush for squeeze out.
Thoughts and techniques? I'm surprised in hindsight I've never experienced this before - is american oak particularly heavy in Tannin?
    1,022.7 KB
Your approach is fine, damp cloth and toothbrush are a sensible approach. Somehow there seems to have been a very fine deposit of something metallic that has caused this to happen. Any metal drilling / grinding nearby recently, could be just a few specs of dust
Interesting - I actually was grinding down some old chisels today and cooling them in the water bucket which I then used to clean the joints with. Really remarkable that this made that much difference.
Annoying but good bit of learning...and hopefully I can get it off without too much drama. Big thanks Peter and Ian.
I was taught not to use water as it will creep into the joint though capillary action, so all I’ve ever done is scrape with something suitable and then a dry wipe. Have you been doing anything with wire wool? The bits from that are plentiful. Should sand off fairly easy.
Yes that is sensible advice and a well taught approach. From a commercial manufacture side it is very fast and produces a great result to use water, particularly warm water, if the wood is properly dry and you have a dry shop, any moisture added during the removal of glue will have gone by a day or so, just need to look out for potential issues like this contamination.
