ByronBlack
Roger, there are two issues I have problems with: Thick stock and long ripping, and large panels.
Crosscuting panels is ok unless they are particularly wide, but it's when rip cutting a panel to size that is problem, they are invariably too long for the MFT, and I either have to resort to moving the guide round so it's straddling the longside, or if the panel is longer than that I have to do it off the MFT - so it really becomes an issue when I have a lot of different size panels that i'm having to change and setup etc.. with my limited time in the workshop I end up spending over half of that just setting up for a particular cut.
90 degree cuts can be a problem on larger panels due to only working from pencil lines; so when there are a number of panels to cut the same size it's difficult to be accurate enough to get them all the same and at 90.
But continuing my thinking, I'm almost sure making a larger MFT is probably the answer, and the thicker stuff can through the bandsaw.
