Woody Alan
so let me get this right, are you saying that I could do away with the sliding table, at the extensions to the right of the saw, and cut panels using an EB3 or similar mitre guage and using the fence as a guide? This would still give me 30" of x-cut which I think should be quite adequate for most tasks.
The limit in use is when the mitre gauge is pulled back towards you assuming a facing the saw stance there is a point where it becomes wobbly and falls of the edge of the table. This distance between the face of the guage and the leading edge of the blade is the maximum panel size to safely cut with the mitre gauge. A sliding table increases the ability to do panels in two ways, firstly the rail extends further towards you beyond the front edge of the saw giving a stable platform for the material, secondly the panel is placed with it's leading edge against the mitre rail further away from you. In other words it would be like putting the mitre guage in the slot the other way round (don't) and pushing the gauge with the work.
The other method using just the fence is just that. You set the distance to cut the panel between the right of the blade and the fence and push the panel through against the fence. I am not a great fan of this method since getting a kick back through stupidity when a panel lifted on the blade (no gauard :roll: ) and fired itself at me and I was on the floor before I realised what had hit me. I hadn't found the resources here to help at that time.
So to conclude either you keep the rails to the right to cut panels or the sliding table to the left or make a sled which I have to say is vastly underated as a cheap means of acheiving what's required. I hope that helps it's not easy to communcate in words something that can be explained in seconds with gestures
Alan
