On Saturday I was ripping some oak to make a face frame for the router table I am building and I ended up with some pieces that were definitely not straight. I was using my Triton Workcentre and the timber was some 19 mm oak flooring off-cuts I rescued from a firewood pile. I know that I should set the fence so that the larger part of the timber is between the fence and the blade, with the narrow piece to the outside, but I wanted quite a few 19 mm strips from several different boards so I set the fence at 20 mm and started ripping. The first piece was ok but by the third I was getting a distinct curve. What was I doing wrong and what is the best way to go about producing a number of pieces the same width without continually moving the fence and introducing errors in size etc.
cheers
George
cheers
George
