Sgian Dubh
I agree; wood can certainly do funny things sometimes. I've experienced similar distortion after sawing thick oak boards.tension can be pretty mental cutting down boards. I've had big oak boards, 12'x200mm that started off straight and flat before it went through the saw and what comes out the other side is bent and twisted and pretty much useless as a long length.
A lot of times it cant be helped given how a tree lays down each layer of growth.Then in the saw mill as its cut green into boards, and kilned with the weight of the multiple boards pressing down it remains relatively straight and flat, til we buy it, where it goes all to hell
Unless of course you happen to own a surface planer
Still, I generally avoid and encourage others to avoid specifying tension as a cause of distortion after cutting a piece of wood. The cause of the distortion might be tension release, or release of another form of stress, or stresses for it's often hard to be sure what form of stress was released. As I said in my earlier post I think it's best just to say stress was released leading to distortion: it covers all bases. For instance, if you cut a piece of wood that's case-hardened it will distort significantly, quite possibly lengthwise as well as widthways: case-hardened boards are in tension at the core and the shell is in compression. Slainte.
