I would be looking at the straightness of the fence or the gap between the fence at the point of cut, i.e leading edge of blade and the gap to the trailing edge.
That is check for “back cutting”.
I would have with the machine safely isolated from all sources of energy, brought the fence as close to the blade as possible and measured the gap, with feeler blades or some kind of slip gauge, between the fence and the nearest edge of a blade tooth. As near to the table surface as possible.
Rotate the blade and repeat at the trailing edge.
The gap must be greater at the back, not by much, fractions of a mm, up to a mm or two, depending on how big the blade is.
The other thing then is a good engineering straight edge along the fence. Check with feeler blades for a gap, a 0.05mm / .0015” (thou and a half) shouldn’t fit down.
Then cut a square off the fence larger than the blade and see if it is square (diagonals), & straight sided (steel straight edge).
Once that is done, if you have a sliding table then you can go on to start looking at that.
I have somewhere the definitive document that the industry refers to for the procedure for aligning fences and sliding tables written by a guy from Altendorf.
Where it is now I don’t know.
IF I ever find it I’ll post it.
@Avery, did you have the saw from new? Have you had the problem since it was new? Have you spoken to SCM about the problem? I know I have done visits for less serious issues for them and Record Power over the years.
