lurker
Le dullard de la commune
IMHO, 60 tooth is no good for ripping, which is what I assume you are doing if you are using the fence
Bob put a micrometer on the teeth and then the Riving knife is the RK wider?
Try a short fence. You can fit a lump of wood through the middle of the box section and then as Jacob says.
There is a good reason why several people are suggesting the short fence and it will take you less than 15 mins to see if we are right.
I have the mankiest of the Charnwood TS range, it is mainly used for sizing recycled (with hidden nails #-o )wood and cutting firewood, for this I use a less than perfect blade.
But with a newer Freud blade the wood comes off the saw in glue ready condition.
