Hello,
I have Axminster 10" table saw, still with its original blade, which has now seen better days.
I need to replace the blade, but I want a good blade for the work I need to do. I don't mind paying a bit extra for something special.
As an example of my needs, I make hardwood boards out of 25mm thick American Black Walnut, Maple, Oak and other hard woods.
A typical board is 20" square but the planks are cut to 3" strips (ripped) then glue back together (alternative species) then cut again (crosscut) into 3" strips before being glued back together.
The end result is like a chess or drafts board (Although not for this).
I want a really good blade for cutting both directions of the board, but with a good enough finish for gluing back together.
So, my question is what would be the best blade for this? A general purpose blade? What make? What about teeth style (Rake & top etc)?
For me personally, I really don't want to be changing the blades each time, unless it really has a massive benefit.
I read the Swedex and CMT blades are good and a few other high end brands, but more specifically is what style of tooth and TPI would be best?
Thank you for any any replies or advice you can give.
