Summerhouse build
ben2
24 Feb 2010
Hi
I thought I would add a conclusion to a couple of topics which I started some time ago
building-pentagon-shaped-building-frames-t88874.html
lots-of-cladding-which-nail-gun-nails-t96410.html
I have added some pictures of the nearly finished article, I’m really pleased with it, it took an unbelievable amount of time to do!.
The method of framing I chose was to do lap joints at all the intersections, suitably strengthened with corner pieces. I used 6 x2 for the bottom half, 4 x 2 for the roof section.
Each frame was then then laminated on both sides with 12mm marine ply (glued and screwed). I made 10 off the them - all were very rigid! Thanks for the advice on this!
The nail gun I went with for the cladding was the Senco – brilliant piece of kit. I ran it off a 25l compressor with no issues. It just worked. I highly recommend it. Senco couldn’t have been more accommodating in supplying it.
You will notice from the internal pictures a few things not quite finished… maybe moving, so now trying to work out how to get it onto a lorry to move it 1.5 miles…answers on a postcard!
Thanks for all those would helped
Mark
    106.8 KB
    84.8 KB
    79.1 KB
    64.5 KB
    101.8 KB
    171.4 KB
    179.9 KB
    188.9 KB
    182.7 KB
That looks fantastic, you must be well pleased! Really like the colour you've used on the outside.
Coley
