Looking really nice, well done. Can I ask how high it is? Curious because the advice you had from your local planning office...
mailee":2koipbhr said:
...I rang the planning dept and was informed the height was 4m for a ridged roof and 1mtr from the boundary.
...is at odds with what I was told when I did my first summerhouse earlier in the year, and also with what's published on the planning portal website -
http://www.planningportal.gov.uk/permissions :-
"Outbuildings and garages to be single storey with maximum eaves height of 2.5 metres and maximum overall height of four metres with a dual pitched roof or three metres for any other roof."
And
"Maximum height of 2.5 metres in the case of a building, enclosure or container within two metres of a boundary of the curtilage of the dwellinghouse."
So, 4m max height for a dual pitched roof, but only 2.5m max if it's within 2 metres of the boundary. Pretty sure the "within 1m of the boundary" is a building regulations thing, e.g. from the PP website again:-
"Building a detached [garage] of less than 30 square metres floor area would not normally need building regulations approval if:
the floor area of the detached [garage] is less than 15 square metres.
the floor area of the [garage] is between 15 square metres and 30 square metres, provided the garage is at least one metre from any boundary, or it is constructed from substantially non-combustible materials."
So if it's less than 15 sq m then building regs don't apply, but if it's within 2 metres of a boundary it can't be higher than 2.5m, that's my understanding anyway. I had to go into this quite carefully as the one I did early in the year was in a conservation area and they're pretty hot on the regs!
My reading of your situation would be that if it's less than 2.5m high then you didn't need to move it, but if it's more than 2.5m high then you perhaps haven't moved it far enough! :shock: Hope it's OK.
Cheers, Pete
