Phill05
It's a joy to see and read of your extremely talented work keep it up please, I am more interested in the carving side but your explanations of how you get there is also needed.
I wasn't really trying to promote my own product, just making a bit of a joke, but since you've asked, I don't sell copies of the book. I leave that to Classic Hand Tools or, in the north-east, Woodsmith Experience. Slainte.
Just come across this thread. It maybe your wood is too dry? Riving is usually done on wood with 30% moisture content on young wood, sounds like you are scavenging freshly cut trees, but have they dried out?Hi thanks for the reply, I find quite a lot of stuff being removed from neighbours gardens, by tree fellers. If there is a piece I think may make a little bowl I get a few logs. I've been working on Bay, as I mentioned what I would call American Oak (the leaves are more spiky than the Turkey Oak in my garden) Turkey Oak and the other day some Holly. I haven't started on the Holly yet and any advice would be very welcome. With the Bay several logs produced lovey radial splits but getting the split to cross the centre takes, for this old bloke, a lot of effort.
Martin
Thank you for this fascinating set of articles, I've just read it from start to this one no 70. I've wondered how riven timber was properly prepared, only really read about it from a furniture perspective. really good read, I look forward to learning some more.What do I do if I'm on my last bit of good oak and I want a 5" muntin, but if I rive it along the rays I'll only get a 3" piece after it's planed ?
By splitting across the rays, you'll end up with a section which looks something like a rift sawn piece.
Rift sawing is a way of converting timber on a mill which looks something like quater sawn. It won't give you the spectacular figuring of true quatersawn, but it does produce a section of timber which is as dimensionally stable as you can get.
So if you've got yourself a decent piece of timber, it's worth trying this and creating stuff for stock instead of throwing it on the woodburner. I'll hew the sapwood off that last little bit and make it into a triangular section.
This will up your yield of quality joinery timber to a percentage which would make a sawmill owner blush.
The last bit will be good for carving picture frames, as they often taper like that. Also this outer piece of the tree, just under the sapwood, is usually the best piece of timber as the annual ring per inch count increases the further you get away from the pith as the tree increases in girth.
This timber is much milder to work than the faster grown timber of smaller diameter trees, but it usually gets thrown away by the mill as slab.
