Mark18PLL
Hello everyone,
I am constructing a stud wall to fill a double doorway to close the room off and have a couple of questions.
We will be plastering the whole wall and not just the opening, so with this in mind i thought it might be best to fit a plasterboard flush with the existing wall on either side, would this be the correct way to do it?
The walls on either side are stone and i was thinking of using the fixings below, i am happy with the length of the screws as i am using 4x2 for the studs but was wondering if i should you a larger diameter, say a 10mm.
https://www.screwfix.com/p/fischer-nylon-hammerfix-8-x-120mm-50-pack/90560
Mark
Mark
