However you repair this inadequate fixing it will happen again unless you make it a more structurally sound fixing, that means drilling deeper with longer fixings into a brick or timber stud, anything else is putting a plaster on a haemorrhage.
I've got a pack of these, circular (about 2" across) mesh disks impregnated with plaster.
Made for this sort of reason, depending on wall of course. Wet the disk, fold it around a rawplug and pop it back into the hole. As it dries, it fixes to both the hole and the plug and becomes solid again.
https://www.amazon.co.uk/WETNFIX-20-DISCS-Fixing-redrill/dp/B01B2ULW7G
Call me a cynical old git but I wouldn't want to bet my PL insurance on using this as an option.I've got a pack of these, circular (about 2" across) mesh disks impregnated with plaster.
I don't think it expands, it just dries solid and fixes the plug back into the slightly expanded hole.That looks brilliant! Do you know if the material actually expands in the hole?
As I said - but wash (or at least blow) the dust out of the hole first.I have remedied this type of situation by using "NoNails" or a similar product, clear any dust from the hole fill it with the adhesive and push in the plug, leave long enough to set -- overnight ? then refit the screws.
