Even 18mm will sag over 1.2M - given time and the weight of the books. I recommend a vertical support in the centre of each shelf.@dzj Do you think the 15mm shelves will sag? I could upgrade them to 18mm, the cost difference is not that much, if that would solve it.
I would have a cross piece behind the drawers that would function like the upstands Richard mentions (although just being the single one). Do you think that would be enough to prevent wracking?
One option would be to add another cross section/back piece from the bottom to halfway to the first shelf.
Edit: like so: (view from the back)
If you were to weigh your books you might be surprised at the result.The Sagulator is a cool little tool. Thanks.
It says that as long as I don't exceed 20kg on a shelf the sag should not be noticible. I won't be loading anywhere near that. 72 cm of paperbacks is probably less than 5 kg.
It's sitting against a wall with thin skirting at the bottom. Floor is linoleum. I might fix it to the wall if needed, it shouldn't be a problem as the skirting is quite thin.is this sitting against a wall with skirting?
does the room have carpet fitted with gripper rod?
if so the unit wont sit back flat to the wall
personally id be tempted to put in some random vertical dividers -wide bookshelves arent very practical as its hard to keep the books dead vertical
Im a little concerned your idea of a shadow gap formed by having the lipping short might look like a badly fitted joint -ie an error rather than a design feature -maybe you might want to make a sample and see....please dont see this as a criticism -just thinking aloud!
Creep.
