ajayre
I have a 12mm plywood sheet with 24mm (2 x 12mm) plywood pieces glued around the edges using Titebond III. This item is going to get banged around, loaded in and out of cars, etc. Should I be concerned that the glue alone won't be enough to keep it together?
I have some wood screws but I understand that screwing into the plywood edges (via the large sheet) would be a bad idea without some fussing with CA glue or other methods to keep the plies together in the long term.
I thought of gluing blocks of wood into the corners then one screw in each direction (side, side, sheet). Would that make much of a difference?
Any other suggestions?
Thanks, Andy
Thanks, Andy
