Stock too thin for hinges
supertom44
27 Dec 2022
Staffordshire
I'm making a wrap around grain tea box for a gift and I planned on using some smart box hinges. However I got carried away milling after resawing it and now it's too thin for the gingers to be morticed into it.
I always planned on adding a contrasting wood lining, which will thicken the sides up.
I have a couple of options
  • Extend height of liner to same height as sides then mortice hinge into side and liner.
  • Skip the hinges altogether and extend the liner above the sides and create a lift top lid.
Wonder what would you do in this situation?
You could still mortice it in, but you'd just have the side of the brass hinge showing. I don't think that would look wrong, especially if you polished it a bit.
Those side rail hinges are typically 8 mm wide although some cheaper versions are a bit narrower. I.make all boxes with 12mm walls now which is probably the optimum size
I'd glue on liners to bulk up the Sidewall. Hinges are more satisfactory with long term use. ?
Interesting I hadn't thought about having the side exposed. This could work, especially if I made the height of the liner to same as the sides to give some extra support.
Thanks for the replies/ideas.
My plans were for the sides to be 12mm, however due to a few compounding mistakes they ended up at 9mm ha.
I think hinges will result in a better end product in terms of function, but not sure if it'll compromise the appearance.
Not seen quadrant hinges before, found some that are 5mm and 7mm thick so they could work.
While looking for those also found these: https://www.prokraft.co.uk/premium-solid-brass-side-rail-hinges.html
6mm rail hinges, if I offset from the outside edge so they line up with the liner, that would give me around 3mm between the outside of the hinge and the outside of the box.
Another option as mentioned above is barrel hinges, from same site found some 5mm barrel hinges: https://www.prokraft.co.uk/solid-brass-barrel-hinges-pair.html
If you could get a nice hydraulic fit for the lid e.g with liners extending from the base into the lid inside I reckon that would be better than hinges.
Tom, I’ve tried those Prokraft rail hinges before and they weren’t good at all. Bad alignment and poor finish. I may have been unlucky and/or they may have improved but thought it worth mentioning.
Is swapping to a butt hinge not viable?
Butt hinges are an option still. Was looking at the ones from smart box maker but they are too big.
Need to look around and see what alternatives are available.
The ones you linked above might be ok, hair too big but can probably work with them still, if not I’m sure I’ll find another project for them.
It looks like there might be enough meat to file the hinges down a bit on either side. 0.5-0.75mm on both sides would allow you to butt the hinge up to the inside edge of the box, leaving it exposed and leave 1-1.5mm wood on the outside edge.
