Well I didn't get going very early today, but I've only just come in, so still a decent day's graft. But it is so much harder on my own.
I started by cutting a length of membrane. The building is square, so I can use the front as a measure:
and I stapled it into place. It would be much easier with two.
The stapler is an Aldi/Lidl special and is generally pants. Ray's never misfires, this one is hit and miss. Sometime double. Ghastly piece of kit.
The staples themselves will not be very robust if it gets windy, so I have to put the laths on pretty much straight away. But I can't put the higher layers of membrane on by myself. so I've only nailed them up so far, so that the upper layers of membrane can be slid underneath.
Then it was on with the cladding I painted yesterday. I found a problem as soon as I started. The cladding fits in between the corner trims, but as the wall is not fully skinned, I couldn't fit the corner trim. So I fixed some offcuts with screws to give me the position and worked to them.
I tapped each length down with a hammer and a scrap of cladding so as not to damage the tongue. It's not easy aligning a full length, I can tell you.
This is what it will end up looking like:
I need to punch one or two nails, but most of them have set themselves. Then I can fill the holes and paint over. Does anyone have any recommendations for a suitable filler, preferably a gun-applied one? I want to be able to squirt, smooth, paint.
I wish Ray would stop faffing about with that bit of a guttering job of his.
