The Shark
Hi Olly,
Nice job!
Malc
Nice job!
Malc
woodbloke":1bkahxx8 said:he recommends a curved sole jack plane to do the dishing...if you follow :? :lol: - Rob
I have a curved sole plane already (a small maple and rosewood one) already Karl, but there just happens to be a nice 2" woody jack in Penny Farthing Tools that would do rather well. I can see a visit into town this weekend is on the cards - RobKarl":1nur3ycg said:woodbloke":1nur3ycg said:he recommends a curved sole jack plane to do the dishing...if you follow :? :lol: - Rob
Not an excuse for another plane, surely :lol:
Karl
Olly - yup, that's the one, based on a design in Alan's book. I don't recollect how Nick dished the seat, but Alan P recommends a 2" woody where the sole has been planed convex and then the cutter is ground to match. The book btw is well worth buying - RobOPJ":26ruanbz said:I think I know the one you mean (although, I haven't yet bought his book... ). Is it similar the the one Nick made in BWW a few months back?
Are you taking the p1ss?Ironballs":19e796b3 said:You can suspend your router on a cable/chain above your piece ...
Hmm think you need to lay down in a dark room for a little while, hopefully the men in white coats are busy and wont call for you tonight. :shock:Ironballs":326bf92z said:You can suspend your router on a cable/chain above your piece (very securely of course) with the cutter in place and extended below the base. Then you can swing (very gently) your router like a pendulum, going lower or your piece going higher after each pass. It will cut a perfect indent and if you so wish a perfect circle with the only marking needed the initial lining up.
They don't call him Ironballs for nothing.DaveL":36t0k77t said:Hmm think you need to lay down in a dark room for a little while, hopefully the men in white coats are busy and wont call for you tonight. :shock:Ironballs":36t0k77t said:You can suspend your router on a cable/chain above your piece (very securely of course) with the cutter in place and extended below the base. Then you can swing (very gently) your router like a pendulum, going lower or your piece going higher after each pass. It will cut a perfect indent and if you so wish a perfect circle with the only marking needed the initial lining up.
This does not sound like a good idea.
I think with care you could make a cradle that slides along the top, which has curved runners the you could slide the router backwards and forwards on thus cutting the curve.
The idea for the router swinging in free space does not appeal, the cut would be a curve in all directions, or is that what you are trying to achieve?
This sounds interesting Damian, if not a bit of a scary :shock: and a vastly over complicated way to do what's basically dead easy with a curved sole plane.Ironballs":2hqkib7m said:There is another way....
