Chris152
Thanks Rorschach, really helpful - in a couple of years he could be off living somewhere far away and it'd probably be time to sell it on, if we do go ahead and buy one - unless I've got hooked on it too! #-o
novocaine":ou7mbyoc said:No you can't have mine.
I hadn't thought of that! Hopefully the school will have it checked and tested - if not, I'll be sure to get a sparky on the case. I'll point it out to him and see if it's been talked about - all good learning.sunnybob":1dy73i7d said:Safety note here though, with an all metal lamp you need to check that "bit of soldering" wiring pretty well and make sure there is a VERY GOOD earth on it.
:shock: :shock:
=D> =D> =D> =D>
Spot on - I'd just updated my last post!Rorschach":3p8p3g1o said:RE: earthing, I doubt a school would be making mains powered projects, I would assume it is battery powered.
Chris152":3qbc5hin said:ps that philips screw's coming off to be replaced with slotted one as soon as it gets home.
J-G":16wg4886 said:Chris152":16wg4886 said:ps that philips screw's coming off to be replaced with slotted one as soon as it gets home.
First - I suspect that the screw recess will be PoziDriv not Philips (but that's just pedantic)
Second - I do hope you mean that the Slotted one will be replaced with a Pozi recessed one - - - or better still a Hexagon socket button head.
The difference is subtle but essentially the Pozi Recess has an extra 'nick' between the 'cross' and is 'tighter' - see the attached image. (note that in this particular image, PoziDriv is incorrectly spelled)Chris152":1d4v5ku6 said:First - no idea!
Yes. - slotted head screws are prone to damage both to the slot itself and the surrounding components due to screwdriver slippage.Chris152":1d4v5ku6 said:Second - I think the slotted one looks better, more simple - tho a hex socket button (I had to look that up online) would look good. But is there a reason beyond the way it looks?
Chris152":32x6efly said:Obviously, we might be needing some new kit if we're to sort it at home... :?
