Starrett square - rule damage
worker
11 Jul 2021
UK
I bought my Starrett combi kit (435ME-300) just over a year ago and today while doing some oiling, I noticed loads of bumps, ridges and scratches on the rule where the combi square head tightens against it.
Has anyone ever seen this before?
I've always treated this thing like a baby, keeping it away from other tools and keeping it in the original box after use. It cost close to £200 as a 'buy once, cry once' purchase so I wasn't planning to let it get damaged!
I only use it a few hours a week at most and part of the reason I bought it because these are supposed to be lifetime tools, within reason.
I'm feeling quite gutted at the moment. I've emailed Starrett to see what they say.
    280.1 KB
    164.2 KB
    411.2 KB
    311.2 KB
    372.5 KB
It says hardened on it, I expected it to be a lot tougher. It's seen very light use
What is the D part like that runs in the slot? from the images it almost looks like the blade has been laminated.
Looks like a rip-off fake.
I've had a Rabone square for about 50 years which has had hundreds of hours of use and misuse but is still good.
Maybe just bin it and buy a cheapo replacement.
If it has taken you a year to see the marks, they can't be too bad.
Starrett quality is not what it once was. Live and learn.
Do the imperfections affect its use or accuracy?
As above, check the part that tightens against the slot to make sure they will not get any worse.
You could dress out those imperfections with a stone or a piece of wet and dry glued to a suitable backing.
If they still bother you, I think the rule might be available on its own as a spare part. Examine it closely on receipt and reject if unsatisfactory.
Have you checked the screw has a clean flat mating surface? A bit of grit embedded in it etc would then indent the steel.
Be hard pressed to say it's not faulty, where did you buy it from as some outlets like "Workshop Heaven" for example offer a lifetime warranty.
Deductions from your pictures....
This isn't about where you are clamping and using the stock as the damage
is right to the ends.
The part that pulls in the groove possibly has sharp edges or a fault which is drawn sideways in the groove and wearing into it.
Combined with the above the spring drawing the two parts together may be excessively strong/long and not allowing enough slack when sliding the stock along
The rule is possibly not hardened properly, even the graduated corners are looking dubbed over.
Cheers, Andy
The 'D' part has no visible imperfections or discolouring.
In the last picture, there is black line inside where it meets the steel so I expect that will get worse over time. I don't know yet if accuracy is affected but it has knocked my confidence in it.
It was purchased from an eBay business seller - I checked with Starrett to confirm they were a known distributor.
There was some dust inside the square head but I don't expect that would damage steel. And no chance of metal getting in there, I don't do any metal work.
The marks look as though they could be machining marks ? where the cutter has torn the material ? But either way it should not be like that -- a replacement would be in order !
I have one which is almost certainly pre WW2 -- I am 80 and got of an old chap who was retiring in the 1960's still as good as the day it was made !
The depth of some of those marks almost look like voids in the metal rather than anything that would be caused by scratching the surface.
Your statutory rights apply here.
As the item is faulty and it is a high quality product that should last many years of service.
You are entitled to a replacement
Please could you be specific on which rights apply for a product which was "bought... ...just over a year ago".
When you state as a fact someone's entitlement, it would be wise to back that up with a reference to the applicable legislation. It gives the statement some proper teeth.
I would be interested to know this as well
You can make a claim for faulty goods up to six years after purchase.
From the which website:
The Consumer Rights Act gives you the legal right to either get a refund for goods that are of unsatisfactory quality, unfit for purpose or not as described, or get it repaired - depending on how long you've owned it:
  • 0-30 days: You can claim a full refund for goods that are of unsatisfactory quality, unfit for purpose or not as described.
  • 30 days-six months: You must give the retailer one opportunity to repair or replace it before you can claim a refund.
  • Six months or longer: You must give the retailer one opportunity to repair or replace it before you can claim a partial refund, and the burden of proof is on you to prove the product is faulty.
I'm currently in the process of returning goods under the second point. An item was faulty, they had it back to fix, made it worse and now it is on it's way back for a refund.
After the initial 12mths warranty.
As a consumer you are further protected by your statutory rights.
Particularly when you buy a high quality item expected to last many years.
I'm not a consumer lawyer so will direct you to trading standards and Citizens Advice for further assistance.
After the 12nths you generally are only entitled to a replacement.
My first though too. I have a M&W one which certainly isn't treated as well as it probably deserves but is 30+ years old and as good as new. How sure are you it is genuine.
