Spraying MDF
Frank88
New member
15 Mar 2020
london
Hello,
I am in the process of building a custom wardrobe (18mm mdf) for my own bedroom and i would like to have a go at spraying it.
I am a painting decorator by trade but this will be the first time i will try spraying mdf.
If all goes well i'm thinking maybe to spray my kitchen doors as at the moment they look a bit crap.
After a tiny bit of research online i decided to buy a devilbiss slg 620 spray gun and im looking to buy a decent compressor that its not too expensive as these will be the only times i will use it.
Also i would need a bit of help deciding what paint i shall use? Bear in mind im intent-ind to spray the mdf in a spare room so maybe water based paint is better suited.
Thank you in advance for taking the time replying.
Have a great weekend!
Frank
We use Morrell's waterborne lacquer for spraying MR MDF.
Hopefully you have used the moisture resistant boards as it makes quite a difference on the edges and a bit of difference on the faces.
They do a white or grey primer and then tinted top coat to whatever colour your like. Sprays very nicely and gives a good finish.
Mike
I would very much recommend "5 Minute Workshop", a weekly series of videos on Youtube (amongst others) by Peter Millard. He's a member of this Forum and his profession is making wardrobes and other fitted furniture out of MDF which he often sprays. Have a Google to find him (title above) and you'll find a wealth of info there, unbiased as far as I can see, and covering both various tool reviews AND his techniques.
HTH
RAF":2vyyw0jt said:
https://www.youtube.com/results?search_query=gid+joiner
This man has many videos in this. Hope it helps you.
+1 for Gid Joiner, the guys a frickin legend....and uses a devibliss
I quite like spraying but wouldn't bother, instead would go (have gone, went) for Tikkurila Helmi with a microfibre roller and a tipping-off brush. It'll give you 90% of the flatness and a whole lot less (i) masking hassle and (ii) stress doing the underside surfaces, deep corners etc. It's super tough and durable as well.
