steamboat
Hello all, I am new to the forum and fairly new to woodworking so have a lot to learn.
This is my first question:
I have been building a pair of loudspeakers for a while now, I have veneered them in figured cherry and plan to lacquer them to a high gloss finish, all going well so far. I am now on the lacquering part which I am doing by spraying; unfortunately this part isn’t going so well. I have sprayed about six coats, sanding in between coats, but I can’t seem to get the lacquer to go on thick enough so that it is wet, instead I get a finish that looks a little like it was put on by flicking a lacquer laden tooth brush over the veneer. I have adjusted and then re-adjusted the gun settings, what can it be???
The compressor is only a 1.5 hp, but I cant see why that would be the prob, the air presser is around 25-30psi I am holding the gun about 6-8 inches away from the work peace.
Please help.
Many thanks
Steve
Please help.
Many thanks
Steve
