Farmer Giles
The biggest tool in the box
I have the under shelf finished and I'm on with the sliding deadman before tackling the tail vice. I doing the deadman before the vice as I am still pontificating about the dog holes and this has an impact on the distance of the vice from the edge of the bench. The instructions from HNT Gordon say that the centre line of the vice should be between 75 and 90mm from the edge of the bench. I'm sure there is a good reason for this so I have taken that into consideration.
Here's my first punt at spacings and number of holes, I may have a few too many! I have based the hole spacing on the parf guide system, i.e. 96mm apart as I bought a "seconds" version of the mk1 system from Axminster a while ago as the price wasn't as eye-watering.
The tail vice has a 150mm throw so I could ignore the parf distance and do that, but I like the idea of using the parf guide system to set out the dog holes. It's a pity the vice doesn't have a 200mm throw or I could have missed out every other hole and have a spacing of 192mm.
So I set out the tail vice centre at 90mm from the edge, this means that the distance from the second row of dog holes on the first half of the bench is 3 x 96mm to the row of holes on the second half of the bench, or parf distances, and places the holes in the second bench bang in the middle of the slab. So I can get a 45 degree angle between front and rear halves of the bench using 3 parf dog spacings etc.
I've decided to use 20mm hold downs only, maybe even have blind holes, not sure about that though, yet, probably get full of crud.
I'm still thinking about spacing and number of holes, thoughts welcome, especially based on experience.
Andy
Andy
